Автор | ![]() |
krb
С нами с: 18.11.2009
Модель телефона: E52
Hi guys!
Cool forum, you are doing great job!
I have question about my Nokia 5800 xm. I would like to install Russian keyboard to send text messages to Russia.
My 5800 xm:
Code: 0577454 JQ16r3I
Nokia 5800d-1b Type RM-428
sw v 21.2.025 18/4/2009
custom ver 21.2.025.263.04 28/5/2009
Lang set 17
As far as I understand, I should perform some steps:
1. Change product code from 0577454 to some Russian code (is 0577454 Ok?) with JAF software
2. Update software from 21.2.025 to 31.0.101 using Nokia Software Updater
Am I right?
Thank you very much!
My 5800 xm:
Lang set 17
Am I right?
4e6yPaToP
Человек года '07
С нами с: 11.10.2006
- krb писал(а):
- Am I right?
- krb писал(а):
- is 0577454 Ok?
- krb писал(а):
- 1. Change product code from 0577454 to some Russian code (is 0577454 Ok?) with JAF software
- krb писал(а):
- 2. Update software from 21.2.025 to 31.0.101 using Nokia Software Updater
Последний раз редактировалось: 4e6yPaToP (18 Ноя 2009 21:34), всего редактировалось 1 раз
krb
- 4e6yPaToP писал(а):
- krb писал(а):
- Am I right?
Thanks man!
But too many options -)
Will Nokia Software Updater work for me?
4e6yPaToP
Человек года '07
- krb писал(а):
- Thanks man!
- krb писал(а):
- Will Nokia Software Updater work for me?
But for different codes there can be different versions of software...
krb
krb
Guys, that’s me again.
It is not that easy to install Russian language into my NA phone!.. –(
I have Type RM-428. I found example «Прошивка RM-428 на RM-356», but I have sw v 21.2.025, not 21.0.025.
And my question is: If I will download via NAVIFIRM sw RM-356 v 31.0.101 and will do same manipulations with files’ names, will it work for me?
Thank you!
Thank you!
krb
fuzzim
С нами с: 09.03.2009
krb, yes, you can use FW 31.0.101 instead FW 21.0.025.
krb
fuzzim, thank you!
Also I found that fw 31.2.008 for RM-428 has Russian language: Israel Black 0581748 (English, Hebrew, Arabic, Russian, Spanish)
What about this option? -)
fuzzim
- krb писал(а):
- Also I found that fw 31.2.008 for RM-428 has Russian language: Israel Black 0581748 (English, Hebrew, Arabic, Russian, Spanish)
Hm, It looks good and you have not to do manipulations with a file names. Also 3G option will be saved (you can disable 3G on you phone by using RM-356, but i'm not sure).
krb
big-tolya
С нами с: 03.12.2009
Модель телефона: 3310))-6260-6125-E71-5800XM
Thanks a lot for this post!!!! Useful!! Israel code works great for rm-428.
Fast changing code with SpCC 1.34 on 0581748 (previous was 0581837), and after that simply update with NSU 1.8.10!! And thats it!!
Got Russian,, Baby!!!
Благодарствую!!! Все у кого f*ckin' black rm-428,, use it!
Новая тема Написать ответ | Главная — Discussion Nokia phones | Часовой пояс: 3 |
